Aller au contenu
Rechercher dans
  • Plus d’options…
Rechercher les résultats qui contiennent…
Rechercher les résultats dans…
sinox
probleme coupur d amplis qd je met trop de basse
Messages recommandés
bonjour voila g mis le testeur 12.4 ha a la baterie 12.3 ha a la masse et au + a mon amplis je pense que 12.4 ha  a la baterie   c trop faible et sa et le test etais fais sans l amplis allume et oqp a jouer j imagine en pleine puissance le crois que je descend a 9 ha voir 8 ha g un aplis fusion
fiche technique de mon amplis.
Brand New - PowerPlant Monoblock Amplifier 3000 Watts - D-Class PP-AM300010
0dB - 12dB Bass Boost @ 45Hz
20Hz-350Hz Frequency Response (-3dB)
40A X 4 Fuse Rating
20K Input Impedance
0.2V - 8V Input Sensitvity
3000 Max Power Rating (Watts)
850 Watts RMS X 1 Channel @ 4 Ohms:
1300 Watts RMS X 1 Channel @ 2 Ohms:
1500 Watts RMS X 1 Channel @ 1 Ohm
>80dB Signal To Noise
1% (100Hz) THD @ Rated Power
6dB / Octave Variable Low Pass Filter
fiche technique caisson.
Rockford Fosgate P3-1X12 Loaded 12" Subwoofer Enclosure
Rockford Fosgate's 12" vented subwoofer enclosure has a peak power rating of 1200 watts and an RMS rating of 600 watts. This enclosure comes equipped with one 12" Rockford Fosgate P3D2-12 dual 2 ohm subwoofer that are constructed with a anodized aluminum heat sinking cone material and a santoprene rubber surround. The subwoofer are loaded into high quality 5/8" MDF vented enclosure that is covered in durable black carpet. This package will enhance your cars audio system immensely.
The Rockford Fosgate Subwoofer has Dual 2 Ohm Voice Coils; internally wired in parallel down to a final impedance of 1 Ohm. For more information regarding subwoofer wiring, please check out our Subwoofer Wiring Diagram
Product Features
12" Punch P3 Series Dual 2 Ohm Subwoofer
Power Handling:
Peak: 1400 watts
RMS: 700 watts
Impedance: 2 ohm
Anodized aluminum heat sinking cone & dustcap for strength and durability
Tall profile true Santoprene vertical attach surround technique increases a speaker's effective radiating cone area
Dual tear & fatigue resistant linear poly cotton spiders
Optimized motor magnetics with extended pole and bumped backplate
Fatigue resistant and reduced strain stitched tinsel leads
Multi point high temp/strength neck joint bonding technique
Sturdy 16 gauge compound bend frame geometry
Semi-Flexible PVC removable protective motor cover
Custom insulated compression input terminal assembly
Proprietary spider venting/cooling technique
Decorative die cast trim ring
Custom 10-AWG nickel plated push terminals
High temperature 4-layer 2-1/2" voice coil with spun laced nomex insulating reinforcement collar
Double stacked ferrite magnet structure
Subwoofer has been internally wired to a final impedance of 1 ohm
Frequency response: 26.5-250 Hz
Sensitivity: 85 dB
Xmax: 16.2 mm
Mounting Depth: 6-11/16"
Cutout Diameter: 11-1/4"
1-year Manufacturer's warranty
Partager ce message
Lien à poster
Partager sur d’autres sites
[img][/img]
pourriez vous de dire a koi sert le reglage de mon amplis et comment puis-je les regler pour que mon amplis se me pas en secu
Partager ce message
Lien à poster
bonjour
les 12ha à mon avis tu as voulu dire 12 volt????
12,4 volt si ton testeur est bien étaloné et pas un testeur bon marché ??
12,4 volt moteur allumé ou eteind ??? a mon avis voiture eteinte ???
l'ampli se coupe quand tu augmente le volume
cela proviens du manque de courant
as tu bien mit ta masse quand je dit bien c'est sur la carrosserie et la carrosserie poncé jusqu'a la tole ????
quel section de cable as tu utilisé de la batterie a l'ampli ????
6²,10²,16²,25²,50² ????
batterie d'origine ou au gel????
avec un ampli de 1500 watts rms une batterie d'origine est insufisante inutile de mettre un condo un condo mise a part l'esthétique cela ne sert a rien ...
pour les réglages
on règle un ampli a l'osciloscope , je me doute que peux en possède un on peux aussi le faire au multimetre cela permet un réglage a environ 90% des capacité de l'ampli je dirai environ 52 volt en sortie (si ma mémoire est bonne)
pour que ton réglage soit +- correct
imput level au 3/4 (meme un peux plus )
lpf a fond (c'est le réglage qui limite les fréquence de sortie de l'ampli a fond tu ouvre toute les fréquence)
subsonic a zéro (un simulateur de basse on va dire)
boost a zéro (un destructeur de sub on peux l'utilisé légèrement mais avec un réglage présci)
tu vas me dire oui mais quand je met du basse boost ca va plus fort
je te dirai c'est faud et c'est facilement verifiable avec un term lab tu shoot avec le bass boost et sans tu verras ton score sera mieux sans boost c'est une fausse impréssion que l'oreil donne
l'impession que cela va plus fort est due a la distortion causé par le sub
voila j'espere que cela t'aidera .
mais ton ampli coupe a 90% a cause d'une mauvaise allim retire le fusible a l'avant et essaye en direct sur la batterie et je suis casi persuadé que ton ampli ne coupera plus cela voudra dire que les cause sité plus haut sont réel
attention ne pas joué sans fusible par la suite cela sert uniquement pour le test
Partager ce message
Lien à poster
merci oui sa m aide car hiere g mis USB test de maximus SPL sa commansais a sentir le bruller jonathan(maximux spl) ma dit de ts diminuer subsonic et boost,sur sertain forum lp freq il me dise de le retire si je le met sa risque pas de me peter le sub?
Partager ce message
Lien à poster
lpf ca rique pas de cassé les sub c'est le volume et la distortion ou surpuissance qui casse le sub
Partager ce message
Lien à poster
  • Créer...
